Driveshaft when going from 9" to quick change
  • rocetwildone
    • 95
    Anybody have the measurement for driveshaft going from 9" to quickchange.
    I am thinking we will all have the same length because there is no more options for different yokes, The only difference would be from a BERT to BRINN or Falcon...
  • js11
    • Apr 2011
    • 91
    32.5" for the Bert if running 4bar stuff with the 8" yoke (6" barrel). You could go 33" with a less aggressive chassis. Not sure about the Brinn.
    • rocetwildone
      • 95
      Thats what i thought.
      Do you know what U joint is needed for quick change yoke?
      • js11
        • Apr 2011
        • 91
        I'm fairly sure that the Spicer number in 1310...but you should check the application specs based on the yoke you are using and the drive shaft manufacturer's recommendation. Sometimes you'll get the wider version (chevy to ford conversion). It's been a while, so it's worth checking to make sure.
        • andy29
          • Sep 2012
          • 33
          1 1/2 to 1 5/8 longer than what you ran with a 9" i think . winters website has all the different housing's measurement information
          • bob75
            • 2814
            shouldnt change ---brinn--falcon---3 speed tarns take 29.5 ----bert 32.5 length
            • Lizardracing
              • 839
              The critical dimensional change will be the distance from axle center line to the U-Joint center line between the QC and 9".
