? on front ends
  • brian-micheal
    • Oct 2013
    • 29
    ? on front ends
    Which of meter or the difference metric fronts with nova lowers with pinto spindals or chevelle front end . I see both and they are fast so what are some of the ups and downs. Thanks I am new to mods
  • Renegade Cust Susp
    • 349
    Have had both. Honestly I like the way my metric drives better.
    Broc Burton
    go.fast.crs@gmail.com
    • brian-micheal
      • Oct 2013
      • 29
      sorry for the spelling it is surpose to be whitch are better front ends and some of thr differences
      • TS3g
        • Oct 2007
        • 201
        Both can be equally fast. Chevelles are weaker frames IMO (horns bend down very easy), and the centerlinks bend if you look at them wrong. Metrics are harder to get proper bump steer, and the nova lowers are weaker. Pick your poison.
        • Bcollins82
          • Jul 2009
          • 322
          In my experience, the metric/nova frontend turns a little better than the chevelle, but the chevelle feels more "comfortable" or predictable.
          • CsR41
            • Aug 2010
            • 169
            DirtRacer9x, Do you just make stuff up so you can reply? I mean really, c'mon. You replied 500 times in the other thread on why they use the metric and you just keep ignoring it all.
            • QQQQ
              • Jan 2014
              • 92
              Chevelle, Metric the Chevelle is a little wider thats it. I dont think a Metric is stronger. I'll take a new Chevelle clip over a 25yr old rusted Metric clip any day. Does one turn better than the other? If it turns better its not because of the clip. And why is a Chevelle easier to build? lol, IDK? Welding tubes is welding tubes. Its all how they are set up, there are fast Metrics and fast Chevelle's and if you have no idea what your doing, they are all slow.
              • MM90
                • Oct 2010
                • 422
                Which is better? An aftermarket Chevelle frame that a chassis builder manipulates when they weld it together or a stock factory Chevelle frame?
                • NAYRBNYLF
                  • Oct 2014
                  • 22
                  I think the 80' full size metric Impala,Is comparable to the chevelle . It's heavierAnd it takes a little work to set up the front end.
                  • Anonymous24
                    • Jan 2014
                    • 253
                    100 percent agree with this. If you are coming here to seek knowledge, have fun and good luck. There is much disinformation here also, don't be learning incorrect information.
                    Find me on Facebook: Impetus Dirt Racing Technologies
                    • 7uptruckracer
                      • May 2009
                      • 1336
                      There are a lot that are running the Ford Clip now because of the steering geometry and width so don't rule them out either.. Metrics have bump steer issues as stated. It depends on rules as well as to what you can do to correct some of the chassis problems. As far as Roll Centers you can put whatever you want under just about any chassis. Just depends on your knowledge and your rules. Metric/ Pinto Combo is good. Hard to get good RF Camber Gain and Bumpsteer but it can be done. Chevelle doesn't need as much work as a metric geometry wise and like they said you can get it in pieces and tweak it as you assemble so thats a Pro.
                      • JustAddDirt
                        • 1893
                        I ran a Ford last 2 years.
                        They drive really well, almost steer too well.
                        I used Pinto spindles on it the first year,68-72 che velle spindles the next year.
                        They were made up to 2002. 03 and later had rack and pinion. and aluminum removable cross member
                        they are plentiful, but have to get to them before the demo derby guys do.
                        • dereksehi
                          • Jun 2013
                          • 307
                          I also have a crown vic stub car setup with the pinto spindles its new I havent had a chance to run it but like said they are supposed to steer very well.
