Spring change
  • pig tracker
    • Feb 2015
    • 104
    Yes I do have a LR brake floater. I'll have to recheck rear steer, can't remember what it is off my head.
    • powerslide
      • 2696
      Brake Floater in the hands of an inexprienced driver/crew chief is just another tool to dial the car out. Plenty of other stuff to work with until you are in the ballpark
      • stock car driver
        • 3233
        Honestly if you cant remember then its likely not where it needs to be there is a reason the same guys are usually up front, they are ensuring every detail is correct when they leave their shop.
        I have marks on my frame I measure rear steer to axle tube distance it seems real critical on these 4 bar cars to me. I can change my car from tight to loose with a few turns of the rs bars.
        • drtrkr244
          • 1024
          On a Bob Pierce car I crewed for, it was too tight with a 650lf, 600rf. I put a 600 in lf and freed it up, then I just adj bars for various track conditions.
          • pig tracker
            • Feb 2015
            • 104
            I can't remember what I did an hour ago, that's why I write everything down in my book. I have it written down but don't remember if it is 1/4" or 1/2". I think it is the front springs also. I've never ran with a softer spring on RF before and I think this is my problem. The car is not a four-bar car it is a long spear-rod. New animal to me. I knew it would take awhile to dial in.
            • pig tracker
              • Feb 2015
              • 104
              Just got home from working on car and checked rear steer and it is set at 1 1/8". J-bar has 4.5" drop(Left chassis mount and ride side of pinion.
              • powerslide
                • 2696
                How are you checking steer? When something is that far off standard I always stand back and give it the eye. You can tell if it really has that much by backing up behind the car and looking at the wheels.
                • pig tracker
                  • Feb 2015
                  • 104
                  60". Motor also has been moved back to center. Have made some changes and will get car back on track in a few days. On a side note: How many RPM drop from a 6:48 to a 6:02?
                  • drtrkr244
                    • 1024
                    4-500, but that will vary depending how your car handles.
                    • pig tracker
                      • Feb 2015
                      • 104
                      OK, been gone for awhile. Ran car 2 weeks ago with some changes. Swapped springs in front(650 RF- 550LF) Car still uses all but 1/2 to 3/4 inch of travel. Also car had 165# of LR before and started out with 100#LR. Car entered a lot better but pushed on throttle at apex out during heat race. Took more LR out(about 35#) Car enters good and will take throttle immediately but at apex pushes straight to out side of track and I have to get off gas and back on. I race again on the 24th. Took a little more out of LR(now 50# LR). Also moved RR bar up one hole and changed RF to a 600 spring. Also noticed my rear stagger is only 1 1/2 inch: really want more like 2 1/2 inch so I'm going to my new tires for rear and see if I can get my stagger right.
                      • MM90
                        • Oct 2010
                        • 422
                        More rear stagger should help your apex.
                        • pig tracker
                          • Feb 2015
                          • 104
                          Thanks for reply.
                          • drtrkr244
                            • 1024
                            Are your spear rods mounted on birdcages? If so, are they floated or solid? Thanks, just curious how you have so much drive.
                            • pig tracker
                              • Feb 2015
                              • 104
                              On cages and floated. Has hellatious bite coming out. Now if I can just get it all the way around the corners. LOL
                              • drtrkr244
                                • 1024
                                Thanks for the info. I think your going the right way with less bite and softer rf spring and more stagger.
                                Is that car a converted 3 or 4 link?
