LR shocks
  • Wheelman33
    • Apr 2008
    • 232
    LR shocks
    Running a UMP mod and curious about the LR shock rule. Says 1 shock per corner but been hearing about a lot of guys running 2 LR shocks. I know UMP will not tech it. So what are you guys doin?
  • washeduptoo
    • 1353
    Some are running a dummy shock with a coil over instead of a slider, might be what you are seeing. Just a thought.
    • Mosidebite
      • 717
      Some are running two live shocks. Some run it on top of the housing to the chassis and others run on front and back of the cage.
      • QQQQ
        • Jan 2014
        • 92
        This is the rule:M.) Only one shock per wheel will be permitted. Lay down shocks less than 12” (twelve inches) away frombrake rotor will not be permitted. Additional shocks in other locations will be permitted.So you can put a 3rd or 4th shock anywhere you want as long as it 12" away from brake rotor. I know I have seen some pierce cars with the 3rd shock mounted inboard on the rear.
        • Mosidebite
          • 717
          And that is illegal....I had it that way past year, 13" away from rotor. UMP made me remove it. I also "appealed"and was denied again....might just be who you are though
          • Anonymous24
            • Jan 2014
            • 253
            BSB eliminators can be made into shock if you a savvy enough to figure it outI do not promote breaking rules, true champions will win legitimately
            Find me on Facebook: Impetus Dirt Racing Technologies
