Drive shaft length
  • stryker69
    • 11
    Drive shaft length
    currently running a Saginaw 3 speed will my drive shaft need to be longer switching to a Bert or Brinn? Can I run the Bert with my steel blow proof bell I'm currently using?
  • Lizardracing
    • 839
    The three speed, Falcons and Brinns are the same length but the Bert is shorter so only the Bert will require a DS change. I do believe you can use you current bell housing but you will still need the block mounted starter and flex plate.
