Emod set up help
  • wayne36
    • Feb 2015
    • 3
    Emod set up help
    I am running a older Howe chassis with mono leaf rear with coil over eliminators and floater 9 and will be running on 3/8 dirt tracks. were is a good starting point as far as set up for this car?FrontLF 700 RF 650LR 175 RR 175 coil over elimenators 55lb mono Leaf
  • Dirtrunner35
    • May 2010
    • 632
    I had a early 2000 ellis with that set up, tacky and rough was great when it slicked off forward bite was alot less
    • wayne36
      • Feb 2015
      • 3
      Do you know a baseline for setup? or what worked best
      • Dirtrunner35
        • May 2010
        • 632
        Same springs that you have, about 80-120 lr bite I always ran in the moisture on the bottom with this car if not forward bite wasn't the best.
        • wayne36
          • Feb 2015
          • 3
          Emod setup
          Thank you for your help
