need help tight in the middle northern sport mod
  • redracersmod
    • Jun 2013
    • 45
    I have a chevelle stub dirtworks its tight in the middle. Most features we run are dry slick. Any help would be great. Here is my setup. Springs lf 500 rf550 lr 200 RR 175, shocks comp/rb lf 5/3 rf3/5 lr gas 8/2 RR 4. Scale weights are as lf 480 rf510 lr 721 rr613. 52.9 cross 51.6 left 57.3 rear. Ride heights are 6 1/4 across the front 7 lr 6 1/4 RR.
  • oldtrackchamp4x
    • 270
    Had a DW-8. Had to run right at 2 1/2 in stagger when it was tight in center and that would free it up. I would try that first. JMO
    • modracr41
      • Oct 2007
      • 243
      Originally posted by DirtRacer9x
      That 3/5 rf. go to 3/6 3/7
      Also try taking out some rear bite. You're around 110 lbs. Drop that back to the 30-40lb range. 110# rear bite and you'll pick up a push when you get back into the throttle (mid turn.) Good luck.
