right rear spring question
  • cgs
    • Jan 2009
    • 91
    anybody run anything lighter than a 175 on thier right rear four bar car? just curious. im going to a play day and was thinking of trying a 150 or 125. car is too tight off throttle into the turns. cant ever seem to get it loose enough for me. anyone have any experience with a lighter spring? thanks in advance!!!
  • UltimateRaceCars
    • Jan 2014
    • 116
    Honestly I would not soften the RR spring to help entry with as soft as you are. The spring affects more than entry and could hurt you center and off more than other adjustments. Add more right lower bar angle or static trail on the RR or space the RR out.
    www.UltimateRaceCars.com
    • powerslide
      • 2696
      What front springs you have?
      • Anonymous24
        • Jan 2014
        • 253
        That's gonna make her roll....weight transfer will be slow. May allow for excessive weight transfer.
        Find me on Facebook: Impetus Dirt Racing Technologies
        • JustAddDirt
          • 1893
          Soften the lf spring
          Raise j-bar on rear end (sorry had typo that said chassis)
          Try a straight panhard bar
          • mod71m
            • 393
            Soften the LF spring.
            Don't be afraid to get a crazy amount softer on the LF spring than the RF. I had to put 200 lbs. softer LF spring than RF in my car to get it to turn on entry. In the heavy I could still go 50 lbs. softer.
            Give the car what it wants, forget about the numbers.
