Right front shock question
  • lewisc7
    • 51
    I have a modified chassis I got as a bare frame. I noticed the right front was designed to run a 9" stroke shock. Is this something common to help prevent the shock from bottoming out? Or is it totally unheard of?
    Been here since 1999.
  • MM90
    • Oct 2010
    • 422
    Not uncommon, seen another driver convert his chassis to run 9" shocks on all 4 corners. Not quite sure on the reasoning behind it, probably a couple different opinions on this subject.
    • powerslide
      • 2696
      More weight to carry. Only use 4-5inches of travel on rf. Leave the 9inches alone.
      • 7uptruckracer
        You run 9inch stroke on rear and some people run a 7" on LF with a 2" Extension so it gives you more droop. a 9" would do the same thing there. So maybe they just used one on the RF relocate the mount so they could just use all the same shocks.
        • drtrkr244
          • 1024
          I have seen a couple mods run this. They had a very tall bumpstop pack. If you and your shock guy were willing to test some, you might could find some benefit. If not, then just do what 7up said and run a 7" with an extension.
          • hammond motorsports
            • 269
            my cars run 9 inch on all 4 . the 9 inch helps to clear the spring better on the rf . Lf helps from picking tire off track .
            http://www.facebook.com/pages/Hammon...26044754164488
            • drtrkr244
              • 1024
              HM, if I might ask, is your framerail higher or just the shock mount? Thanks in advance.
                • 269
                yes my front horns are about 1 inch higher then radiator
