Sportmod panhard bar adjustment
  • Elam Budmore
    • Dec 2014
    • 14
    Can I get some guidelines as to what different adjustments to this bar will make. such as what adjustments you should make if the car has a push at turn entry or loose on entry or mid turn etc.
  • kwagner
    • Nov 2008
    • 50
    I'm interested in hearing some info on this as well.
    • 3dracer
      • 421
      Lower bar is lower roll center. That means more roll. But if you have too much angle, it will make it tight on entry off the throttle
      • Elam Budmore
        • Dec 2014
        • 14
        Ok... when you say "to much"? angle, what type of bar angle range would you start with? there are 3 holes for adjustment on the rearend,from the lowest to the highest is maybe 4" differance, if that. Right now the bar is all the waydown, what conditions would warrent moving the bar on the rearend to the top hole? what effect would/should this have on the car at corner entry,mid turn,and exit?
        • 3dracer
          • 421
          Start with it centered at the pinion on the rear end, and 4 inches higher on the frame. Good starting spot
          • slim269
            • Jun 2013
            • 36
            16 to18 degrees
            • drtrkr25rjr
              • Apr 2015
              • 5
              Invest in a climber mount for the frame mount. Generally, moving it 1" up or down makes a noticeable difference to the handling. Move it up (on frame) to tighten car on entry and center and down will loosen.
              • Dirtrunner35
                • May 2010
                • 632
                lower roll center is more roll but less weight transfer
