We've checked for binds, everything moves freely but car just doesn't lift. I was wondering since he is a big guy do we need to increase lr spring, say going from a 200 to a 250 or is there something I missing. Have changed pull bar biscuits, still not there yet. Thanks for any information.
car not lifting
This is a spring behind mod, also its not getting onto rf, still has about 2.5in of shock travel left. I have a 16in 150 spring already set to go in, hoped to try after races last night but it was a late night, normally run a 13in 200lr spring. More angle in lrt bar or something else? Thanks
What is your driver saying about how the car is driving?I've seen cars that were loose off and the driver couldn't get back on the gas to get it on the bars.What shock numbers?
He said it drives real good, don't have shock numbers with me, they are with car at his shop. They are custom shocks though, tried several different ones on rf an lr, still the same. Went from a 600rf down to a 500rf. Still the same results. I hope to remove rf spring and see if its some kind on bind there, just had it out this past week, so not expecting problems there. Thanks
Its hard to say what we have changed since we redone the front end(ball joints different) and we've been running a bump stop on rf because last year it would bottom shock out and didn't want to tear up this new shock. I took that shock off and installed a different shock and that's when we saw the issue with shock travel. I think its the chain on lr to short, we let it out last week and bent lrb bar, so I shortened to specs. Going to get a prebent lrb bar and set the lrt bar angle at 45 and see what that changes. Thanks
If the car is competitive i wouldn't worry about it getting full RF comp. I changed my front clip and the car is getting on the RF 2 inches less than before. The car was fast in practice last week and i will know more after this Friday nights race. Really, if the car is fast it does not really matter. JMO
I agree on getting more LR drop. I've ran up to 52 Deg full drop. Might be worth a try, especially on the slick. Just make sure it doesn't go over center. JMO
I think that is why it bent lrb bar last weekend, we've been trying many different things this year and we're still in that process. Different ball joints, springs,shocks bar lengths, jbar settings,etc., just trying to get faster. I like the way things are going so far, been fun and stressful. lol Thanks
I know what you mean. Whenever i strap in after i make i make a new change, i am also a little stressed. Lol. JMO
If it bent the LRB bar it is getting on the bars...
When you start messing with all the balljoints you start moving the roll center around maybe you have the roll center higher.
That was last week it bent the bar when I had the chain lengthen but I'm pretty sure it hasn't been getting on rf. It could be the ball joints. Going to put prebent bar on lrb and set drop to 45degrees on lrt bar and see what kind of travel we get on rf. That should tell us if its the ball joints and we can put others back in rf for the next week if needed. ThanksLast edited by washeduptoo; 04-27-2015, 10:21 AM.
