Too short right rear chain
  • hunterracing
    • Jan 2009
    • 303
    Would having the rr chain so tight like it barely raises 1/2 from ride height. Cause to bust tires loose on very exit bcs rr comes off the ground when I jack up left rear before the left rear chain is tight
  • 35smod
    • 286
    You need an 1 1/2 to 2 inches from ride height to let your suspension still work it might not be your only problem but its definitely not helping
    • hunterracing
      • Jan 2009
      • 303
      Yea I kinda figure it would be most of it beside maybe to stuff left rear shock
      • Duckhnter83
        • Apr 2013
        • 152
        What's the purpose of a chain on the RR?
        • stock car driver
          • 3233
          No, not unless its causing you to bounce up and down from a rough track.
          there are chassis out there that run their chains tight to 1/2 loose all the time
          • hunterracing
            • Jan 2009
            • 303
            Everything is good goin in center then apex it turns sideways I raised pullbar and right top bar neither helped.. Driveshaft doesn't bottom out.. Would stiff of left rear shock cause it..
            • Duckhnter83
              • Apr 2013
              • 152
              What does a chain do on the RR?
              • 25drtrkr
                • May 2015
                • 856
                By chaining the RR down, you are trying to keep the car from climbing up on the bars. The more angle the rr bars have the less drive you have. Also, you would lower the right top bar if you needed more drive.If you're busting both tires loose, I would look at increasing rear weight or lengthening and softening fifth coil.
                • Duckhnter83
                  • Apr 2013
                  • 152
                  Would it help on a 2 bar car like a sport mod with springs on top housing solid bird cages? We add bar angle to gain traction on the RR
                  • save the racers
                    • May 2013
                    • 271
                    We put a go-pro camera on the r/r.With certain angles it would slam in to the chain so fast and hard it would upset the car.Lowering the r/s bars will take rear steer out.It is a balancing act.Raising the r/s bars can add r/r traction, but if the r/r has to much traction over the l/r it can be loose on the gas.It's like the r/r is out driving the l/r.
