RR Spring in front or behind?
  • Dirt Dobber
    • Nov 2014
    • 19
    New to mods... running a 602... i have seen alot of posts/info/debate about the left side spring placement but i was wondering about the RR? I currently am running the Spring and slder behind with the the shock in front on RR as well as LR. Is this in ballpark???
  • Confused?
    • Apr 2009
    • 418
    My experience with that was it made the car looser. Couldn't get a good feel for the rr. Most prefer the coilover in front on the rr.
    • Fox_hunter42
      • 570
      i ran lr spring in front, rr spring behind
      • swartzman
        • 718
        harris had a lot of cars that way years ago..
        • Windy
          • 42
          r.r. spring and shock in front of axle housing on 4 bar..(spring behind loss of feel,sidbite and traction..bad,bad,bad..unless on a clamped 3 bar setup..get you a coilover kit for a r.r. shock and change A.S.A.P. ..windy..~V~..
          • TS3g
            • Oct 2007
            • 201
            What suspension/birdcages are you running? That will make a difference on where to place the springs.
            As a general rule for the RR though, you want the suspension to rotate into the spring on corner entry when off throttle, so if the spring is floated (mounted to the birdcage), put it in front, but if its clamped (mounted to the axle), put it behind.
