Loose, loose, and loose.
  • washeduptoo
    • 1353
    That's great, congrats, best of luck next race.
    • ambonci21
      • 63
      Dirt racer, we do run the shock behind on the rr. j bar rake is like 6" if I remember correctly 7 3/4 up on frame and bottom hole on the pinion. rr is still ahead of lr by 1/4", why do you ask? Just curious
      • ambonci21
        • 63
        RR spring is a 13" 175, shock is a bilstein 30/30. Not sure on slider angle, I will check it tomorrow. whats a good angle to be at running this setup. I do know that we are only getting 2-3" of shock travel on RR. I doesn't get on the RR that much. RR offset wheel is 4" this past week we won the track was used up slick little rubbered up and dusty. thanks. what are the benefits going to a coil over vs shock behind on the RR?
        • ambonci21
          • 63
          same shock as we run now? I hope to try it before the end of the season
          • oldtrackchamp4x
            • 270
            If you won your last race i would think about not changing anything. Make sure you write down exactly how car was setup that night, and track conditions. If you do decide to make a change you can put car back like it was. And don't be too concerned about how much you are compressing the rr as the track, according to you, was dry slick and dusty. JMO
