rr wheel offset
  • brett4
    • Sep 2010
    • 88
    rr wheel offset
    anyone having luck with moving the rr out and actually adding sidebite or keeping the sidebite in the car longer???
  • dereksehi
    • Jun 2013
    • 307
    To add sidebite to the right rear you would usually pull the rr in towards the car.
      Originally posted by DirtRacer9x
      Yes we tried it with 3" offset, j bar split fairly large and 150-175 rr in at 20-25*. Worked well and didn't cook rr
      Hard to cook a tire with no weight on it.
      • Flyin Iowan
        • 558
        ive never felt more sidebite by moving RR in, nor liked how it felt.
        Chris Zogg
        • 25drtrkr
          • May 2015
          • 856
          What tires are you guys on that are saying more offset is taking away sidebite? If that's the case, I would think you are possibly overloading your RR.
          • brett4
            • Sep 2010
            • 88
            chevelle frame,pinto spindles 2 offs on front and left rear.....4 off on right rear with 1" spacer
            • ambonci21
              • 63
              Agreed with dirt racer. Makes a big difference on our cae
              • 25drtrkr
                • May 2015
                • 856
                tighter/looser? and off/on gas? What tires?
                • ambonci21
                  • 63
                  overall tighter everywhere. Way better side bite. we did it that way on banked tires and flat tracks both big and small. IMCA tires.
                  • 25drtrkr
                    • May 2015
                    • 856
                    It has more weight on it in further. So of course it has better grip.....Ο
                    I thought the topic was less offset, not more.
                    • 25drtrkr
                      • May 2015
                      • 856
                      Several have posted that less offset made their car tighter. So explain how less weight on RR makes a car tighter???
                      • anissa5
                        • Jul 2010
                        • 79
                        It adds more left rear less weight to right rear.Running more offset can loosen off corner because to much weight on right rear
                        • 25drtrkr
                          • May 2015
                          • 856
                          Some have posted that it made entry tighter. That's whats hard to understand when the RR will be less loaded.
                          • anissa5
                            • Jul 2010
                            • 79
                            Years ago we use to add wheel spacer to right front and soften the rf spring for entry we did not like to add more offset to right rear but we also ran ump tires. Some cars may transfer more weight then some I always ran a 2 off on right rear
