3-link Setup
  • racehard24
    • Aug 2009
    • 69
    3-link Setup
    I am helping someone out that has to run a 3 Link this year. Rules are 15" minimum lowers, can be 2 inch difference side to side. Angles on both sides have to be within 5degrees. springs must be on same side as well as shocks but can be run on a coilover on each side, solid pullbar. Basically the springs, if left side shock is in back right side has to be in back and left side spring is in front right side has to be in front but both shock and spring could be on coilver on front or back. Looking for a good setup to run with. Running a chevelle clip. Looking for spring rates, bar angles, where to put the spring and shocks, j-bar rake, soild pullbar angle and length, bite, rear percent, left side. If you could PM me what to run that is good and works.
