advantage of offset rearend housing?
  • vrbka7v
    • May 2013
    • 11
    What would be the advantage of running a rearend housing with the center section offset 2" to the left?
  • Dirtmod13
    • Jan 2014
    • 245
    Let's the upper link be adjusted 2" further to the left, driveshaft moves over also so it is still inline with upper link per the rules. A few guys are doing it and winning.
    • Dirtmod13
      • Jan 2014
      • 245
      Bmod rules say driveshaft and pullbar must be inline when viewed from above.
      • MidwestExpress
        • Apr 2010
        • 33
        Never said it was for a Bmod. Could be talking Open mods. Assuming vrbka7v rules are like most open modified rules. The Pullbar does not need to be inline with the driveshaft.
        • vrbka7v
          • May 2013
          • 11
          Its for a northern sport mod so the pullbar does have to be in line with the driveshaft. What affect would having the pull bar 2" further to the left on the rear end have?
          • Confused?
            • Apr 2009
            • 418
            It loads the LR tire a little more than the RR under throttle
            • Dirtmod13
              • Jan 2014
              • 245
              Thought so, how did you hear about it? It's pretty hush- hush for the quick guys around here.
              • vrbka7v
                • May 2013
                • 11
                The guy I bought my chassis said he had one in it. He said it gave him more drive off the corners.
                • dereksehi
                  • Jun 2013
                  • 307
                  If you offset the pinion to the left but not the engine and the pullbar has to be centered over the driveshaft wouldn't that mean the pullbar would not be square with the centerline of the chassis? I would think this could make the car inconsistent unless I'm missing something.
                  • 25drtrkr
                    • May 2015
                    • 856
                    The main issue is the increased indexing of the lr birdcage. Basically, you are shortening the effective length of the upper left trailing arm, thereby increasing the load on the lr. Although not as drastic, you could just space the trailing arm away from the birdcage.
                    • Confused?
                      • Apr 2009
                      • 418
                      Northern Sport Mods do not use birdcages. It's solid three link car.
                      • Dirtmod13
                        • Jan 2014
                        • 245
                        Correct. No indexing. The whole rearend rotates a little that's it. In my area the cars with this are quite a bit faster.
                        • 25drtrkr
                          • May 2015
                          • 856
                          Gotcha.....still some slight indexing into the spring depending on where its mounted.
