Pullbar angle?
  • hunterracing
    • Jan 2009
    • 303
    Pullbar angle?
    Would less angle help gain more traction on very exit of track and hold it longer down straightway and not bust them loose? Brassmonkey medium biscuit travel bout 1 1/4 middle hole rearend 16 to 17 degrees
  • washeduptoo
    • 1353
    It might help with instant traction, it should give more traction down straight. I don't know what brassmonkey biscuit are, but what do they say travel should be with that biscuit? You have preload in it? Is it mounted in front of center line, at center line or behind center line of rear end? Just some things to think about.
    Best of luck
    • hunterracing
      • Jan 2009
      • 303
      Medium bushing mounted in front of housing calls 1/4 I put more in Saturday didt really help.. So would raising on housing and frame be better or lowering on housing and raising on frame a hole or two be better more momentum track
      • washeduptoo
        • 1353
        Try one end at a time in you can to see what it does, around 14-15 degrees might help you. How many bushing bar is this and are they small or the very large bushings?
        • Confused?
          • Apr 2009
          • 418
          Lowering it on the housing "softens" the rate and raising it "stiffens" the rate of the biscuits. It changes the leverage ratio on the pullbar.
          • hunterracing
            • Jan 2009
            • 303
            But lowering will take some angle out which should make traction last longer correct but also have more leverage
            • JustAddDirt
              • 1893
              pullbar
              yes you are correct, and no you are not correct.
              If you lower the pull bar mount on rear end, you are effectively softening the rate of the pull bar, and taking leverage away from it.
              if your pull bar is traveling the proper distance, like 1 3/4-2 1/4" then you need to be moving up and down on the chassis, not the rear end.
              I have moved up pull bar on rear end and chassis mounts over 4" since the beginning of the year, and each time I have moved it up my traction has increased. but there is a limit.
              depends on spring, or biscuit rate, length of pull bar.
              I am at 18º on pull bar angle.
              • hunterracing
                • Jan 2009
                • 303
                I'm middle hole now and bottom hole frame traveling 11/4 on biscuit 5 inch long but that's what there calling for on travel
                • stock car driver
                  • 3233
                  raise on rearend will give you more instant traction when first on the gas... but it can run out on the straight.
                  18 degrees is where I run, my old car liked 22.
                  • washeduptoo
                    • 1353
                    How long is your pull bar hunterracing, we're running a long pull bar with 14-15 degrees of angle. JAD, Confused and SCD are correct and have provided me with excellent information in the past. Best of luck
                    • hunterracing
                      • Jan 2009
                      • 303
                      34 inches long
                      • washeduptoo
                        • 1353
                        Is your pb at the front all the way to the left, what about on the rear end? One thing we have found with the long pb for us it also affects how a car handles.
                        • hunterracing
                          • Jan 2009
                          • 303
                          Almost in both
                          • washeduptoo
                            • 1353
                            If your thinking your biscuit might be soft or hard, you could move the pb down on rear end or up. Might save you from buying different biscuits. Just a thought.
                            • dirtracer07x
                              • Aug 2014
                              • 101
                              dont mean to hijack this but do the same priciples apply for a solid pull bar on a bmod? i have really been wondering about this. we have to keep ours within 1in of centerline of driveline. 1 more question on my lower link where they mount to the rearend there are 2 sets of holes about 1in apart how does the leverage change the car when its a 3link with solid pull bar?
