Pullbar Spring
  • eclipsegse
    • Apr 2010
    • 95
    Pullbar Spring
    What happens if u soften spring rate versus stiffing spring rate in pullbar
  • jamminjayman5
    • Oct 2013
    • 63
    It slows the reaction down and will sometimes make the car seem lazy and slow to rotate
    • MM90
      • Oct 2010
      • 422
      Softer for slick, Stiffer for tacky. To put it into basic terms. I went from a 1200# to a Progressive and could tell the car was lazier in the middle of the corner when I picked up the throttle. Had to retrain my right foot.
      • Team EERC
        • Oct 2012
        • 40
        A softer Rate does not make more traction in any situation. some drivers like a softer rate but its usually because they have issues in other places or a ratchet leg and there's no cure for the later. A three stage system is ideal its the best of both worlds basically.
        EFR Motorsports / Team EERC
        www.teameerc.com
        erik@teameerc.com
        Contact: Erik Edgar
        573-330-8462
        6103 Highway DD
        Farmington Mo 63640
        • anissa5
          • Jul 2010
          • 79
          What if your on the clamped set-up
          • Team EERC
            • Oct 2012
            • 40
            If you are clamped then its a whole different ball game you need more travel to allow the suspension to build traction. So in that case yes a softer rate can provide more traction. with that said I would look more at where the location is on the rear to increase travel instead of going to a softer rate. lowering on the housing will make the spring act softer and on a clamp car you generally don't need as much angle anyway. If you would like more detailed info feel fee to call the shop any time.
            www.teameerc.com
            erik@teameerc.com
            Contact: Erik Edgar
            573-330-8462
            6103 Highway DD
            Farmington Mo 63640
            • ambonci21
              • 63
              Does moving the pull bar down on the housing tighten car up overall?
              • anissa5
                • Jul 2010
                • 79
                Team EERC What rate should you use on the clamp I have always used a 600/ 1200
                • Team EERC
                  • Oct 2012
                  • 40
                  The rate really depends on where it mounted on the rear end. Get me the height from centerline and where it is front to rear in relation to center and what tire you're on. With that I can get you what you need.
                  www.teameerc.com
                  erik@teameerc.com
                  Contact: Erik Edgar
                  573-330-8462
                  6103 Highway DD
                  Farmington Mo 63640
