rear deck/roof braces
  • Flyin Iowan
    • 558
    Ive seen in pictures and cant tell the material these are or where to find them. Ive seen cars using them off the right of the cage to the roof and on the rear deck support going from post to outer edge of deck. Any help?
    Chris Zogg
  • 25drtrkr
    • May 2015
    • 856
    I copied BWRC and made mine out of 1/2" round tubing. Flattened the ends in a press. Very rigid and economical.
    • donmod
      • 96
      the slotted flat aluminum strap from allstar?
      • Flyin Iowan
        • 558
        these look like alum/steel/?? rods
        Chris Zogg
        • UltimateRaceCars
          • Jan 2014
          • 116
          I have used the small aluminum tubing method or use the adjustable aluminum hex spoiler braces that are made for asphalt bodies.
          www.UltimateRaceCars.com
          • Racer96m
            • 425
            These? http://www.closeracingsupply.com/html/new_products.html
            • Flyin Iowan
              • 558
              those i have. looking for something stronger for roof. i think i found some at AR Bodies, or ill just use some shifter rod
              Chris Zogg
              • JustAddDirt
                • 1893
                I use shifter rod with heims.
                somehow about feature time the rear of the roof gets higher and the RF gets lower. I cannot figure out how tho.....
                • JustAddDirt
                  • 1893
                  Magic
                  [QUOTE=stock car driver;1972319]Must have magic expanding aluminum to use for ur sail panels. And never make the tech area![/QUOTE
                  All sail panels front and rear are bowed. When ran threw tech at beginning of night, It all passes. After feature,all is checked is weight, and sometimes tire compounds.
                  I race UMP.
                  • lilsumo
                    • Jul 2011
                    • 154
                    Unless you race at PRP, then you have to pass tech before the race, during the race, after the race, on the trailer on your way home, while getting diesel for the truck. They even want to come to your garage and pull a surprise tech session.
                    • JustAddDirt
                      • 1893
                      prp
                      They are about the only one in the area that tech's like that, I think they are a little extreme with the power.
                      Too bad it is 4+hours away from me...lol
                      I am not real fond of the track anyway.
                      • hipower17
                        • 643
                        i think close racing supply has these. lilsumo is about right on the tech.
                        • JustAddDirt
                          • 1893
                          roof
                          [QUOTE=stock car driver;1972498]
                          Originally posted by JustAddDirt View Post
                          yeah its 2015 mine are also bowed as are about everyones.. That still doesn't let the back of my roof be raised up without undoing the rivets on the top of the sail attaching it to the roof. Maybe yours is attached different, post some pics please. Mine has about 20 inches of sail to roof over lap.
                          I will look to see if I can find a good photo that shows it.
                          P.M me an e-mail address or a number to send them too if you don't mind
