Chaining the RR down?
  • shaw33
    • Jul 2009
    • 54
    Word on the street around here is the new thing is chaining the RR. Is anyone doing this or heard of it? I might just be stupid but I don't know how it could help
  • 3dracer
    • 421
    Been done for several years. All it really does is tighten up the center.
    • ChadJacks
      • Sep 2012
      • 39
      Really tightens up through center off on the gas. Very effective and sensitive, takes a while to find the sweet spot... Would never want to use on a rough track though.
        • 14304
        It doesn't let the rr bar up. It is very common for the rr spring to unload up the straights on a 4 link car.
        • shaw33
          • Jul 2009
          • 54
          So you just mount the chain to the axle? And pretty much set it tight at ride height and play with it from there do dial it in?
          • Lizardracing
            • 839
            Wouldn't the proper shock on the RR help the timing with this?
            You want the the RR doing the same amount of work as the LR when in a straight line but not on the last portion of the exit as the loads are still favoring the RR. That seems like a shock adjustment to me.
              • 14304
              Yes. You can help yourself adjusting RR rebound for sure.
