i know guys are putting it on there tires for car shows,but if the guy is not soaking his tires why are so many putting cellophane around there tires that are in there trailers or car for the race weekend???
tire cellophane
I do it every week. The main reason I do it is I'm the only guy that works on the car, so I'm getting tires ready all week for the weekend. When I'm done sipeing, grooving and grinding, I wrap it and put it in the rack, I usually have many other things to do at the track and we all know how time consuming tires can be. At the track, unwrap the one you want and its fresh, like you just did it.
Dave2012 UMP Stock Car National Champions.
It keeps the like new. And if you actually take the time to clean them properly it keeps them clean while rolling around the shop as well. When I unload at the track I keep it on until I roll out to practice. If you take one tire and wrap and it. And another tire unwrapped. See if its no difference when you punch them in about a week
it helps preserve the oils that are in the rubber. the oils evaporate over time, especially if you grind the tires. always keep your tires clean, stored out of direct sunlight and out of excessive heat. i do not advise prepping your tires through the week unless you have to. perform all prep work at the racetrack. prepping of tires removes the hardened layer of rubber that seals the oils into the rubber. it is the rubber oils that keep the tire working. once the oils are removed, the tire is no longer any good for use. treating your tires allows for these oils to evaporate even faster.Last edited by Anonymous24; 01-03-2016, 11:39 AM.Find me on Facebook: Impetus Dirt Racing Technologies
