2 inch offset rearend
  • mod11h
    • 32
    I see a trend lately of cars with 2 inch offset rear ends. I know pierce cars has used them for years but what is the benefit of using one.
  • junebug
    • 363
    It moves jbar liftbar/ pullbar all 2" left which should all tighten the car...it does also move the mass of the rear to the left adding some more left side weight
    • JustAddDirt
      • 1893
      original poster did not state if it was a 2" left or a 2" right offset.
      that information would be helpful to know to determine what the change would accomplish.
      • junebug
        • 363
        Yep didn't say which direction...I just assumed he was meaning left...I think that's more the trend lately...but not sure what pierce is doing they maybe right
        • Renegade Cust Susp
          • 349
          Pierce cars are set up 2" offset, Leftside tube is the short one. I do know they are not the only cars built/set up this way.
          I'm pretty sure the old Ellis stuff especially spring leaf stuff was the opposite. And they were 3".
          Broc Burton
          go.fast.crs@gmail.com
          • junebug
            • 363
            I assumed that's what he meant be cuz that's the trend of what I've been seeing on alot of cars
            • mod11h
              • 32
              Not sure on which side the offset is going. Im just trying to understand the reason they are going this way. i think its trying to tighten the car up through the corner.
              • xxxmod
                • Jan 2012
                • 111
                I believe the shorter left side axle promotes better forward drive
                than a centered rearend. Having the left side axle twist less than the
                right under acceleration is the reason.Remember,the LR is getting driven into
                the ground harder than the right on the gas.Having a centered rear is not the
                end of the world for most cars and using some of the high quality axles available
                makes a noticeable difference in a centered rearend.
                • TeamGRT12x
                  • 911
                  A 60" centered rear end uses different length axles
                  Curious that we spend more time congratulating people who have succeeded than encouraging people who have not.
                  • xxxmod
                    • Jan 2012
                    • 111
                    ? not a quick change
                    • Kromulous
                      • 3008
                      LOL i never would of thought of axle twist, can you really tell a difference?
                      Krom.
                      Just say no...
                      • xxxmod
                        • Jan 2012
                        • 111
                        The stopwatch tells the difference.
                        • powerslide
                          • 2696
                          It changes how close/far away the pullbar/liftarm is to the RR tire and where the j-bar mounts in the same relation. I would think that would have more bearing than axle twist.
                          • stpmotorsports
                            • 138
                            An offset rearend does not necessarily move the pullbar laterally in the car, in order to make that change you would have to move the chassis mounts in order to keep the pullbar alignment correct. We put a 2" offset 9" in a GRT car last year, and certainly noticed an improvement in the way the car drove. Another advantage is that an offset 9" uses equal length axles.
