I run pro shocks just the oil shocks.. ?I have seen some guys run then upside down but mostly on the right side of the car what does running then upside down do? I have nevver done it that way..... Thanks
shocks turned over
Smebody told me running them upside dne that the oil would not get hot and foam up sooo I should not do that then rgt???? Thanks again
Ok thanks.. But it I dont want to run them upside down like I always have will that be ok... Or does it matter, I dnt want to run them upside down if I dont have to... THANKS AGAIN FOR THE INFO
You don't have to run them upside down if you don't want to. Secondly running them upside down has no effect on foaming(cavitation) or over heating. Running them upside down is strictly a sprung weight advantage. Years ago some cheaper shocks wouldn't function upside down due to air pockets in the shocks, if you turned those shocks upside down the air pocket was put right at the base valve and could effect performance. Modern dual tubes don't suffer this problem if assembled correctly, so you can run upside down if you want to, but you don't have to.Originally posted by frontrunner View PostOk thanks.. But it I dont want to run them upside down like I always have will that be ok... Or does it matter, I dnt want to run them upside down if I dont have to... THANKS AGAIN FOR THE INFO"If racing were easy, everybody would do it."
#77 Leon "Slick" Sells
I think what they are doing is just running the right front upside down so the body of the shock doesn't hit the upper control arm with the soft right front spring in the car and increased travel of todays setups. Correct me if I'm wrong. I know everybody has a ding in their shock where the upper control arm has hit before....
Very good point.Originally posted by hotrod4890 View PostI think what they are doing is just running the right front upside down so the body of the shock doesn't hit the upper control arm with the soft right front spring in the car and increased travel of todays setups. Correct me if I'm wrong. I know everybody has a ding in their shock where the upper control arm has hit before...."If racing were easy, everybody would do it."
