i have a dw9. swing arm 13" in LR.. long 2 link bar 21 in" RR 500 LF 500RF 350 LR 175 RR. coil over on swing arm. spring on top rr. shock in front rear end rr. i have to weight jack turned all the way down on rr. and about turn down about 4" on coil over on lr. will and car work and drive ok with all rr in it? or will it 3 wheel bad? thanks for your help. it is my frist year in mod.
Will all right rear work?
have you scaled the car? if you havent, try getting the frame heights to dw9 specs and you should be close.
im not understanding waht you are asking us. You havent told us what the bite numbers are but you are asking if all the RR will work. like mentioned get R/H close and bite close to what they suggest and it shouldnt be too far out of the ball park. 3wheeling will highly depend on how much lr drop you run. i suggest in the 4-5in range depending on track conditions. measure where the ginger bread man is or close to it.
