Fuel Pressure issues with alcohol
  • dirttrackrocker
    • Nov 2010
    • 664
    PROBLEM SOLVED. Return line is -8 all the way back to tank, but tank fitting is -6. The tool that had the car before spliced the -8 and -6 hoses together with a brass fitting that only had about a 3/16 hole through it. I went straight to the -6 fitting with the -8 hose and double clamped it.
    Idles around 4 now...
    Thanks for the help
    • eclipsegse
      • Apr 2010
      • 95
      i run the same setup on my mod the regulator is at the back of fuel log and returns to tank fuel pressure is hooked up in middle of fuel log and we run about 5.5 to 6 psi at idle with a mechanical pump
