Yoke spacing @ the trans?
  • hanginitout
    • 584
    What should the distance be between the end of the transmission, and the top of the yoke? (I E) how much of the yoke in trans? how much out?.... Setting on jack stand.. Thanks...
    The Bible tells us to love our neighbors, and also are enemies; probably because they are generally the same people...
    G.K. Chesterton
  • langdonracing48
    • Dec 2013
    • 183
    Needs to be at least 2" inside the trans, and no closer than 2" from bottoming out in the trans
    • a25rjr
      • 3774
      Yep^^^^, If you are using the long yoke, push it all the way in until it bottoms out, then pull it out 2 inches. Then measure center to center of ujoints for driveshaft length. I have never had a driveshaft come out using this method.
      Turn LEFT, Vote RIGHT!
      • hanginitout
        • 584
        What suspension ? 4 bar mod?
        Yes its a 4 bar... Its on jck stands and it has around two inches of spacing.... thanks guys!!!
        G.K. Chesterton
