dry slick gearing question
  • Deish98
    • Jan 2012
    • 238
    I run a quick change if I run a 607 gear do I need to go up to 614 or down to 597 on dry slick just needing to know which way I need to go
  • Confused?
    • Apr 2009
    • 418
    Something you should try either way. I prefer a lower gear for dry. Some prefer a higher gear.
    • oldtrackchamp4x
      • 270
      If you are good at easing off the throttle on corner entry, a lower gear might work for you, if not go higher. I would try both as Confused said. JMO.
      • mod88s
        • 226
        More gear. When its dry, you are on the throttle less so you need the gear. And its easier to control wheel spin
        • MM90
          • Oct 2010
          • 422
          I liked lower gear in my car, but my engine also liked to be lugged more than screaming rpm. Going from a 5.29 to 5.14 9" made a big difference for me. So there are a few variables, the beauty of the qc is you can dial it in better and faster.
          • Confused?
            • Apr 2009
            • 418
            A lower gear has a higher number. 5.29 is lower than a 5.14
            • Flyin Iowan
              • 558
              i would change it to keep rpms the same.
              Chris Zogg
