getting up on rr bars
  • racingjf9
    • May 2016
    • 25
    sorry bottoms r 14.1/8
    • powerslide
      • 2696
      If you are still at 19 on the upper you could stand to lose a coupe more degrees. What is the rr lower at?
      And what is the LRU upper/lower at? Just because its 46 at drop doesn't mean you have the correct starting angle. you may just have more drop than others to get to that but you are saying the car doesn't hike so that number is some what of a moot point.
      • racingjf9
        • May 2016
        • 25
        that 19 is when it is in the hole that shaw says to put it i never check it when i drop it was at track 3 or4 diff times just trying to see wat it do rr bottom level lr up bar 22 lr bottom 6 i have try so much running out of things to try
        • JustAddDirt
          • 1893
          I run a standard bolt together clamp ring, with 2 ears on it for a double shear for the chain to bolt up.
          • racingjf9
            • May 2016
            • 25
            clamp right to the tube no bearing type like the lr it dnt bind nothing up
            • racingjf9
              • May 2016
              • 25
              justadddirt with that clamp to the tube it dnt try to bind any thing when its up on jbar pulling rearend to left or trying to rap up i had some isuse before doing that but if u say it will work sure it will u allways bad fast ALL THE TIME
              • JustAddDirt
                • 1893
                My rear end does not move a lot on pinion rotation, so I have the clamp connected to rearend with the chain mount rotated slightly forward. This location was determined by the amount of pinion rotation I have, and setting the mount straight up to the chassis mount.
                I use an Allstar bolt together double sheer mount, and I have a vertical slug welded on chassis, and a 1/2 bolt welded to chassis end of the chain that goes up threw slug so I can set the amount of preload on RR chain. Also I have the chain set at the same angle as the RR coilover.
                never had any binding issues to speak of.
                • racingjf9
                  • May 2016
                  • 25
                  thanks justadddirt i no wat i got to do i ran lightning 4 about 15 years my driver had to go out of town 4 a couple years i sold out i bought this car only had 5 or 6 races on it got a deal i got to call don this fall got to have a car thats wat i got to do thanks for the help JAD
                  • JustAddDirt
                    • 1893
                    no problem anytime
                    • racingjf9
                      • May 2016
                      • 25
                      just add dirt the birdcage on rr of that car is 10 inches wide having trouble getting that chain on the right angle got any ideas on that JAD SURE APPDECIACE THE HELP MAN
                      • JustAddDirt
                        • 1893
                        clamp
                        can you use the inside clamp ring of birdcage and weld the chain mount to? Or, take off the current ring and put the bolt together ring on and use it for the inner holding ring?
                        what about moving birdcage out a bit on axle tube? make your RR bars toe in toward chassis mount at ride height. When cars is up on bars and rear end pulls to left then the bars will be straight.
                        • fatman_74
                          • Dec 2010
                          • 34
                          Originally posted by JustAddDirt View Post
                          Chain it down on rr. Start with about 1/2" of ride height being tight.
                          Tighten to 0 as track slicks off.
                          Should tighten considerably middle-off
                          I'm having the same problem so are you saying chain it so that the chain is 1/2" from tight at ride height? And I was also thinking of chaining it at the back of the birdcage where a rear shock would mount. Any opinions and help would be great. Thanks
                          • Confused?
                            • Apr 2009
                            • 418
                            He's referring to 1/2" of slack. Meaning, if you jack up the RR, the body/frame only raises 1/2" before the tire does.
                            Mounting the chain to the back of the birdcage, where the shock mounts, removes the slack when the birdcage indexes. I think it's a bad idea. Too uncontrollable and immeasurable.
                            • JustAddDirt
                              • 1893
                              Chain
                              Agree, do not use a chain on back of birdcage. Use the axle tube to chassis to mount.
                              • racingjf9
                                • May 2016
                                • 25
                                listen to him thanks JUST ADD DIRT
