I just have a quick question about strange oval kera axles do they work and are they worth the money? Any thoughts. Thanks a head of time
Strange oval axles
Think about this for a minute. There are several "springs" in your driveline. The crankshaft, the u joints, the drive shaft, the pinion shaft, the axles, the tire sidewall. Which spring is much softer than the rest? (The tire)Originally posted by modracer18 View PostI just have a quick question about strange oval kera axles do they work and are they worth the money? Any thoughts. Thanks a head of time
We calculate dual spring rate systems as spring A*spring B/(spring A+spring B).
Lets plug in A=1000 and B=100
The answer is 90.9.
Lets double the stiff spring. (A=2000, B=100)
The answer is 95.
Now double the soft one. (A=1000, B=200)
The answer is 166.Modern Day Spec Wedge Racing
tired them, made a difference. Made my car loose. went back to standard. $250 per axle cost to much to fine tune for me. I have 2 in my trailer if your interested PM me and ill get you length and sizeChris Zogg
Back to Back on a test day?Originally posted by Flyin Iowan View Posttired them, made a difference. Made my car loose. went back to standard. $250 per axle cost to much to fine tune for me. I have 2 in my trailer if your interested PM me and ill get you length and sizeModern Day Spec Wedge Racing
no, ran half a year at the same track, making adjustments and just couldnt get car right. on all track conditions. changed axles went back to base setup then made same adjustments on all track conditions and the car was tighter. my biggest problem was i went with the suggested axles from the speed shop and he was putting smaller LR axles in then RR. It made the car rotate too much and i couldnt adjust out of it. and with my rearend being offset I couldnt just swap axles and was not going to spend $250 for another one. These might work for others but 90% of the time i dont need my car to rotate better.Chris Zogg
The point of them is to make the car rotate better... with less stagger etc. Sounds like your saying they worked perfectly for you.
Are they not advertised as a way to balance out torque steer upon acceleration?Originally posted by stock car driver View PostThe point of them is to make the car rotate better... with less stagger etc. Sounds like your saying they worked perfectly for you.Modern Day Spec Wedge Racing
Originally posted by MasterSbilt_Racer View PostAre they not advertised as a way to balance out torque steer upon acceleration?
yes and they worked perfectly for him he did not shove the nose, his car was loose, he can buy another one and straighten it up some if he chooses, they work exactly like they say its not rocket science. Not that you really care you just want to argue with me for some reason, you should try getting a life.
Don't flatter yourself. I thought you spoke of entry, not exit. And those effects would be opposite. Trying to gather info here.Originally posted by stock car driver View Postyes and they worked perfectly for him he did not shove the nose, his car was loose, he can buy another one and straighten it up some if he chooses, they work exactly like they say its not rocket science. Not that you really care you just want to argue with me for some reason, you should try getting a life.Last edited by MasterSbilt_Racer; 07-14-2016, 10:11 AM.Modern Day Spec Wedge Racing
bahaha, everyone has seen your m.o on here, you follow me around like a lap dog looking for a treat. people aren't that naïve.Originally posted by MasterSbilt_Racer View PostDon't flatter yourself. I thought you spoke of entry, not exit. And those effects would be opposite. Trying to gather info here.
Ill block you, so I wont have to deal with your stupidity in the future. adios
