I know this is mattter of personal prefference, but was wondering which front clip ona mod is the easiest to set up for a best geometry? and stability and strenght, and available parts? between a metric front stub or chevelle, Which top name builds a good metric, and which a chevelle. thanks...
Chevelle or Metric?
Chevelle or Metric?
The Bible tells us to love our neighbors, and also are enemies; probably because they are generally the same people...
G.K. ChestertonTags: None
I would use a OEM frame if you can find a Chevelle go that way but if you can not then go metric . Both metric and chevelle stubs have the same good points and same bad points .
early 70's Monte Carlo as well.
same points as a Chevelle but more tire clearance in the elbow.
I prefer Metric chassis myself, and if you are allowed to run tubular lower a-arms I would use a Lightning or Ruhlman Fold Crown Vic lower.I think there should be lifeguards in the genepool.
Thanks to all.... It helps a lotThe Bible tells us to love our neighbors, and also are enemies; probably because they are generally the same people...
G.K. Chesterton
Like what year? who builds a good metric frame chassis? i know several build chevelle.. does Impressive use chevelle?Originally posted by let-r-eat View PostNewer Caprice clip.The Bible tells us to love our neighbors, and also are enemies; probably because they are generally the same people...
G.K. Chesterton
Metric
I have a Bandit Metric that I have had for a few seasons, and im pretty sure they will still build metric cars.Originally posted by hanginitout View PostLike what year? who builds a good metric frame chassis? i know several build chevelle.. does Impressive use chevelle?
other options would be Lightning, ruhlman, diamond(not sure he still does them) and pierce. Those are probably your most popular/best options on metric cars.Broc Burton
go.fast.crs@gmail.com
I have a Lightning, so I am partial to them.
Ruhlman is also has a good front end design.
Bandit's aren't bad either, I think they are building a lot of Chevelle's now
Stay away from Pierce, not a good design, or redesign.I think there should be lifeguards in the genepool.
just looking for the best front end geometry i can find, i know there are alot of good stuff out there. and was wondering if the chevelle to metric. I thought Diamond was chevelle?,,, I didn't even know you could use ford lowers on a metric clip.. Can you use them on chevelle? and where do you get them? our rules allow tubular lowers. Again thank you for all the info.. keep it coming.The Bible tells us to love our neighbors, and also are enemies; probably because they are generally the same people...
G.K. Chesterton
Where can a person get a good system or artical on when and what to change, to fix front end geometry. i know enought to be dangerous. which is little..
G.K. Chesterton
The problem is not whats right or wrong, works or doesn't, but what design fits the rest of the car. Balanced handling is what your looking for and the means you have to look at the entire package including the driver so theory is about all there is.
