Tire help
  • kyleschornick23
    • May 2014
    • 13
    Tire help
    I race at Lawrenceburg speedway with the tire rule of mandatory H on RR and AS on the other 3 corners. My tires worked great until the lap 17 caution then they were gone on the restart !! Any suggestions on how to keep the tires happy under yellow flag conditions?
  • Fox_hunter42
    • 570
    that is a common complaint with the AS.
    • wallbangerII
      • 55
      L burg
      Looked fast to me
      • dkibel
        • Sep 2015
        • 28
        I ran across this article the other day and I thought it might be worth the read, 3/4 of the way down they ask a question about glazing tires. http://www.hotrod.com/articles/dirt-...ing-tips-pros/
        • old fan
          • Jan 2016
          • 4191
          thats a great article
          • Lizardracing
            • 839
            That happens all the time with American Racers.
            The heat build up on a long green and the tire are hard enough to not shed properly so the oil leach out. Under caution the tires cool quite a bit and the pores close up leaving the hard rubber at the surface. About all you can do is try not to overheat the tire, buzz em in the grit to clean them off. Sometimes the inner tire foams and bead lock inner and outer covers help hold in heat. Sometimes too much heat so be careful there. Grooving and siping seem to help control the temps as well as getting them to refire after a caution.
            • kyleschornick23
              • May 2014
              • 13
              Great article it's nice getting ppls opinions
