Guys im redoing my motor and Im looking for a new cam. Standard bmod motor. scat crank, 6in rods, flat tops, 9.5-1, dart ss heads 76cc chamber, 2701 intake and 4412 carb. 2500 pound car. small and big 3/8's tracks
Bmod motor camshaft recomendations
www.jonescams.com ....all you need to knowMember of the Luxemburg Speedway Hall of Fame
Class of 2019
Karl Performance Camshafts Small Block ChevroletThe Results speak for themselves!Karl Performance camshafts are ground to our exact specs and tolerances; and manufactured in the USA. Our professional machinists have teamed up with racers across the country to develop this series of solid lifter cam(not a nice word)shafts. After rigorous R&D on all types of track configurations and conditions; we feel the series of KP camshafts will give you the exact performance you've been looking for. This series of camshafts is also the chosen brand used in many of our complete engine packages available.--In Dur. @ .050†248°Ex. Dur. @ .050 251°In. Lift .531Ex. Lift .542Lobe Sep. 106°Adv. In. Dur. 279°Adv. Ex. Dur. 282°Valve Lash .016/.016
· In Dur. @ .050†248°· Ex. Dur. @ .050 252°· In. Lift .531· Ex. Lift .537· Lobe Sep. 106°· Adv. In. Dur. 278°· Adv. Ex. Dur. 282°· Valve Lash .016/.018
We've run the 108 and 106 in several engines with very good results but they've all been 12.5 or more compression and the 108 may be a little much for a 9.5 engine. We'll know shortly as I'm just finishing a 10.5-1 355 with good heads with the 108. The 106 may be better for your application. Ours' are bought through Summit and it's my understanding that several speed shops handle these under their own brand name. Summit part numbers are SUM-CT---(fill in the number 101-110) and he cams without lifters are about $82. Don't think Karl's manufactures them but I could be wrong about that.
This is what's in the motor now. Would I gain much with new cam
Would I gain much with a new cam over this?Attached Files
Can't get the images to come up so ?? I will add that with the 108 I almost always run 1.6 rockers on both intake & exhaust which bring the lifts up to .566 & .577. If You're running 76cc heads & flattops you should have plenty of clearance but always check.
What I like about Mike Jones is he can build any lift.. any duration... any LC with his equipment and computer programs. Plus you talk to the guy who grinds your cam not a telephone expert. He grinds cams for the OEM'S when they are designing new engines...Member of the Luxemburg Speedway Hall of Fame
Class of 2019
Thanks justramit and Krooser. The Howard cam is pretty close to the 108. Had a couple of their's when Howard Johansen was one of the better southern California grinders back in the '60s and '70s and was happy with them. Still buy a lot of hard core engine stuff from them in Wisconsin. Never used Jones but his reputation is excellent and I agree it's nice to talk directly with a knowledgeable guy like him. Used to do this with Schneider and Ed Iskendarian and Sig Erson and got some good stuff from all. It's a different world now and more confusing than ever.
Current cam495 lift, during @ 020 281 / 289Intake centerline 101,Duration @ 050 252/260Lobelia separation 105
