dart block 18* top end new eagle 4340 crank 350m 6in rods new ferrer ss valves new erson offset lifters,td 1.5 1.6 rockers---ran on dyno 20 min with 30# breakin oil 650hp cranged oil to 20-50bradpenn installed in mod went racing 6laps in heat started popping pulled in----- 3&5 cyln, were cooler than others- pulled valve covers #5 ex rocker lock nut was lying in head #3 ex lock was lose tore down #3  exaust valves were bent 3&5 lifters were galled in block my eng guy says he will cover the fix but we were wondering what caused problem he says he is sure the lock nuts were tight
-- any help would be appr thanks for your time
