i have one on my motor it was on there when i bought the motor but i do not have it hooked up but the sending unit is in the water neck which works fine if you are not running a thermostat like i have on my alky motor
I use a pressure switch mounted in my water pump. I just drilled and tapped it and screwed it in. It lights a light if my water psi is below 6.5lbs... The light is a trailer side marker on my dash I cant miss it..
