What hp and tq can I expect from this combo?
sbc on alky, 1/4 mile slick track.
dart little m block
4 stage dry sump
45# 3.335 crank
6.2 rod
14.5-1 comp
4.145 bore
16* 270 cnc heads ( brodix )
053 bowtie 2-pc fully ported intake
1.75 int 1.6 ex rockers ( jesel )
.937 lifters
jesel belt drive
4-7 swap comp cam
intk dur @ .050 268
ex dur @ .050 269
int lift at valve 743
ex lift at valve 653
108 lobe sep
2.150 int valve
1.625 ex valve
custom 850cfm pro system carb
1 3/4 step 1 7/8 pipes
wanting a top end engine. Will this combo work? What can I change?
dart little m block
4 stage dry sump
45# 3.335 crank
6.2 rod
14.5-1 comp
4.145 bore
.937 lifters
jesel belt drive
4-7 swap comp cam
intk dur @ .050 268
ex dur @ .050 269
108 lobe sep
2.150 int valve
1.625 ex valve
