I'm building a steel block 406 with alum 23 deg heads with roller cam and wet sump. I'm also considering running it on E85, if that makes a difference in this discussion. I'm not looking to turn super high rpm's, just make good torque with a fairly wide band and a target of about, 600 to 650HP. I've seen several posts on here talking about runner cc and head flow rates, but thats not an area I'm real versed in. What kind of runner cc or flow rate should I be looking for in the package I'm putting together. I was looking at Mullins race engine 23's, but somebody said they thought you had to turn them up pretty hard to make power, I'm looking at maybe turning mid 7's. Does this package sound doable? Any tips, info or advice would be appreciated.
Runner cc question
220-235 runners will work if the rest of the combination is well designed. The Mullins head is a nice piece but for only 600-650hp, you can go cheaper.
Besides the heads, the correct camshaft is essential. If it is in the budget, have the heads flowed and the camshaft deigned to work with them.
What heads would you use?Originally posted by hpontap View Post220-235 runners will work if the rest of the combination is well designed. The Mullins head is a nice piece but for only 600-650hp, you can go cheaper.
Besides the heads, the correct camshaft is essential. If it is in the budget, have the heads flowed and the camshaft deigned to work with them."If racing were easy, everybody would do it."
#77 Leon "Slick" Sells
Thanks. I went over to the edelbrock website and found the Super Victor, but I had to get the part number from summit. For some reason it wasn't listed in the chevy manifolds section. Are the Dart manifolds any good? Just as a frame of reference how hard do you guys turn your dlm stuff? Thanks for your input and advice.Originally posted by ptodd View PostFor what you want i would use the dart pro 1 cnc with a super victor intakeLast edited by F22 RAPTOR; 04-27-2011, 03:55 PM."If racing were easy, everybody would do it."
In our DLM, we usually use a 8200 or 8400 rpm chip and we get up against it right at the end of the straight if our gear is right...It is a 422" SB2.2 ...
So realistically. how hard should I turn a 406 with 23 deg heads? My goal is to build more for longevity and economy than just all out power. I thought 7 to 7.5 would be plenty...Originally posted by sj valley dave View PostIn our DLM, we usually use a 8200 or 8400 rpm chip and we get up against it right at the end of the straight if our gear is right...It is a 422" SB2.2 ..."If racing were easy, everybody would do it."
It was a roller engine with a Willy's 750 on a Super Victor, 13:1 type deal. It didn't roll over on it's nose at 8,000, it would keep pulling, but why twist it any tighter with a 23* head was our reasoning...
Which 23 deg head and cam combo would you recommend? I'm trying to get the whole package to work together in a 406(4.125x3.75).Originally posted by dylchris View PostIMO if you run it higher than 7600 you are running it out of the making power band and into the making noise band. As stated above, cam and head combination will achieve a wide torque band and driveable power."If racing were easy, everybody would do it."
