Ignition step up
  • KAGE
    • Feb 2011
    • 10
    Ignition step up
    Have been advised to put in a unit to step up our msd ign to 18v......
    What is the best product to use ????
    When installing, do you have to feed 18v to both the hard wire ( that would be connected directly to the + on the battery ) as well as the ign switch wire to make it all work with 18v ????
  • ep33510
    • 927
    Ignition step up
    Kage
    We build a 20volt voltage regulator called Maxpwr20, the suggestion is worth considering. The unit allows your ignition program to get everything out of the system possible. In general a MSD is a Happier camper if the voltage & current being fed to it change very little during operation. If your interested check out www.techwestracing.com/page21.html. Also if your looking for how these are hooked up check https://www.techwestracing.com/maxpw...r20blk1008.ppt. If you have any questions I would be happy to answer them.
    Pat Collins
    TechWest Racing Services
    704-995-4286
    Pat Collins
    MSD®Ignition Upgrade / Repair/ Technical Support
    8904 Sutherland Dr
    Huntersville,NC. 28078
    704-995-4286
    techwest@techwestracing.com
