Was told without disassembling the head to weight the valve there is no way to tell whether a valve is steel or titanium tonight at my rules meeting. Is this true?
How to Tech for Titanium Valves?
A magnet doesn't stick to most stainless steels either, Most Ti valves also have a hardend steel insert on top where the rocker rides..... One give away is that most Ti valves have flat faces, NO dish or tulip on the face (chamber side) All steel valves have a dish, to save weight.Last edited by fast_crew; 12-01-2010, 06:33 AM.Josh K.
They only makes valves out of two types of material. Titanium or stainless. Even stock valves are made of stainless. Much like crankshafts are all steel. Some are forged and others cast. Some cranks now days are made of a blend of steel with alloys. But that is an entire different convrsation.
I'm sorry but they make stainless valves flat on the face as well. Classes that mandate a valve size but not compression limits use these to increase compression. the only problem is....they do not flow very well. I have a handful of used ones at the shop if you would like to see one. I think they are all Manley valves.
The only way to check for titanium valves is to pull a head off and disassemble the head.JD's Performance
13034 Hwy 99
Wapello, IA 52653
319-931-0677
Most all the titanium stuff we run either has Hardened Tips that you can see or we run Lash caps..which we don't run with stainless...just my thoughts
Can a motor builder elaborate on this? I would love for a track to be able to tech for ti valves without having to pull a head off. are they a diff color or any other clear identifiers
