oil cooler help
  • leafsovrbrs
    • 82
    oil cooler help
    need some help installing cooler on our mod-- have all parts--just need a diagram of where the lines go--expecialy comeing out of the oil filter block off- will have a remote filter--also will i have to fill hoses before starting--the filter is a ford type if that matters-- thanks--
  • sj valley dave
    • 1016
    With our wet sump Super Stock, we ran from the block off plate to a remote 2 qt filter, then from there to the oil cooler and back into the engine. We used #12 hose. Just turn the engine over some before firing it and you're fine...
