KB Claimer piston compression issues
  • Kojak_9x
    • 179
    Running KB Claimer pistons .465 dome true 14-1 comprssion (alky). Engine is down on power, did compression test cold and only had 150 psi. So i warmed the engine and it dropped to 120 psi!!! Shouldnt it easily be 200-220? With these pistons/alky/bore the ring end gap factor is .03248 comp ring gap which i set at .033. Engine has 7 races on it but only 2 since it sat for 3 years. Im guessing the rings are gone? Anyone else run these pistons/have this issue? Thanks
  • usafracer
    • Jun 2010
    • 554
    Sounds more like a valve spring problem. A leakdown test will confirm.
    • let-r-eat
      • 2319
      Would need cam specs to guestimate.
      BUCKLE UP NOW, YA HEAR?
      • Kojak_9x
        • 179
        Advertised Duration (Int/Exh): 304/312
        Duration @ .050 (Int/Exh): 268/276
        Gross Valve Lift (Int/Exh): .576/.586
        LSA/ICL: 106/102
        Could the valve lash be a tick tight?
        • fast_crew
          • 844
          With that big of a cam, that compression reading is about right. What size engine is this? Cam seems really big, low to mid 260's with about 4* split would really liven the thing up. Give some more details of the combo, heads, intake, CI. A better check of engine health would be to perform a leak down check.
          Josh K.
          • Kojak_9x
            • 179
            .060 350, dart platinum 230cc, 64cc 2.08/1.6. Victor jr intake.Yes i know heads are to big but this thing was running insane and stupid fast. 7 races since freshened (cracked block)
            What do u mean by mid 260's & 4* split? Duration? Lsa?
            Power loss im feelin- last week in the heat was wet slick only turned 7k rpm should of been bouncing of the rev limiter set at 8k ( ive turned this motor 9400 on a 1/2 mile track with no issues) this is a big 3/8 track and im running a 6.00 gear! The main was slick up top and i only turned 7200 and car wasnt spinning tires. The engine hit 7600 in the shop but obviously no load on it! It feels like i lost 100 hp on the track.This is in a mod 4/4. Wanted to run tonight but thought about tearing it down to see if i can find anything!
            • Egoracing
              • 4852
              KB claimer pistons over 9000???? You more than likley killed the pistons.
              • Kojak_9x
                • 179
                Dont want to argue with what i should be running. Just looking for help with current issue. That was prior to being freashened everything checked out. Have to run 8k chip now USRA rules.
                • Kojak_9x
                  • 179
                  Well i feel like an idiot!!! I have a double adjustable gas peddle and the arm cam lose just enough that it wasnt opening the trottle all the way!
                  • Chico
                    • 766
                    hey at least it was an easy fix sometimes crap like that you will chase for a month
                    my daughter my sailor my hero the next greatest generation is our men and women now in harms way Pray for them
