Hey guys. Have a question. Just got done assembling engine , and some guys are telling me my bearing clearance is to tight. Its a 350 chevy, ( .040 over) with stock crank, and stock rods that were resized / shotpeened with arp bolts. Its a 2 barrel ( stock rochester) engine , and it probally makes 275 hp max. It is in a 3200 lb street stock, and i and it will be spinning 6700 max, but would like to keep it to 6300 or so. I have the Mahle lightweight pistons,10.1 true comp and its been balanced.My rod clearance is .002 and mains are .025. Side clearance was .011, and end play was .005. My buddies are saying this is to tight. Any opinions are greatly appreciated. I hate to take it back apart if i don't have to, but i will if need be. Thanks in advance.
Rod and Main bearing clearance
Hey Fast. The one i used has rollers on it, and it didn't mark the bearings, so i don't think it dug into them. I fired it today, and everything looks good so far. No blow by and good oil pressure. Thanks for the reply Ford.I guess the only thing that worries me is the stock rods at 6500 , but we have to run them at this track, so no other choice.I will know after next sunday. hahahaha. Thanks for the replys.
Some times plasti gauge is more accurate then some of the cheap bore gauges guys use with ridgid fingers as then don't work when checking bearing with eccentricty.Originally posted by sj valley dave View PostHope it's not plasti gauge..
I have had a lot of bore gauge wars at my shop over the years and those cheap gauges don't compare to my Sunnen. I clearance out a lot of rotators and my circle track customers and street and strip customers check my work with it and its never been a problem.
Its pretty simple how a peice of wax string works. It has surely bailed alot of guys over the years.
Plasti gauge gets a bad rap. It's actually better than some think if used correctly. Last week I compared a clearance check on a sbc. My Sunnen read exactly the same as Plasti gauge everywhere we checked.Originally posted by CNC BLOCKS View PostSome times plasti gauge is more accurate then some of the cheap bore gauges guys use with ridgid fingers as then don't work when checking bearing with eccentricty.
I agree 100 % those cheap bore gauges should not be used for checking bearing clearances period. Just ask the guys at Mahle!!Originally posted by Rodz View PostPlasti gauge gets a bad rap. It's actually better than some think if used correctly. Last week I compared a clearance check on a sbc. My Sunnen read exactly the same as Plasti gauge everywhere we checked.
