Setting up a motor in a metric
  • Lgss11
    • Jan 2012
    • 22
    Some help please i am putting in a engine in a metric chassis street stock what degree of tilt should the motor be set at should I use tall motor mounts or short ones motor needs to be in stock location don't what to put anything in a bind thanks dave
  • Dirt Knife
    • Jun 2012
    • 147
    With the tall mounts you would be raising the cars center of gravity even higher
    presuming a street stock
    I would use the lower ones
    Tilt /angle unless you are running a track like Slinger WI.
    I'd put it level
    just an opinion
    • dirty white boy
      • 1238
      need to be thinking drive line angle,...how motor is mounted in relation to drive shaft an rear end all comes into play... in your rules "stock location" is bout engine set back,..not its height or pitch!!
      white trash motorsports
      • Lgss11
        • Jan 2012
        • 22
        Thank you for info just thought motor should have some angle and tilt degree for weight transfer and corner dive
        • DaveBauerSS6
          • Jun 2010
          • 566
          High as you can. Set the mounts with the intake, carb and air filter on the motor. The hood sits low to the cross member on these cars. If you can put a hole in the hood; watch the header clearance also.
          Gator Engineering
          • Lgss11
            • Jan 2012
            • 22
            I make these they bolt in.
            http://www.ebay.com/itm/300646524863...84.m1555.l2649
            I also have one inch lower.
            These are what I what but need them by wednesday what is the space between pan and crossmember thanks for help
            • Lgss11
              • Jan 2012
              • 22
              Can I get your phone number or call me at 847 658 4522 so I can place a order
              • Lgss11
                • Jan 2012
                • 22
                Thank you very much for your help dave
