4412 engine build
  • newguy
    • Jan 2011
    • 170
    4412 engine build
    looking for help on building a motor that will be strictly for a 4412. looking into either a 383 or 406. what weight should i be looking for on crank, rods, pistons, and pointers would be appreciated. 3000 lb superstock class, 3 link suspension, imca g60 tire.
  • fast_crew
    • 844
    Callies CompStar Comet crank approx. 43lbs, K1 lightweight Honda Jrnl. Rods. Lightweight Forged pistons, with a thin ring pack (.043 or 1.2mm) Wiseco has a nice package. As much compression as you are able to get.
    Josh K.
    • stockcar5
      • 1289
      go with the 400. use a dart shp block if allowed.
      • newguy
        • Jan 2011
        • 170
        thanx guys, is anything over a 406 over kill? if im going to go with the shp block should i go bigger?
        • perfconn
          • 3636
          Carburetor will automaticaly limit how many cubic inches you should run.With a legal 4412 I wouldn't build any bigger than a 362ci.It doesn't matter how many cubic inches you can legally run,its what the carburetor can feed.
          • perfconn
            • 3636
            All that means is that your 362 is junk.
            • 26-62 racing
              • Dec 2009
              • 147
              Stock Car Driver
              What block are you using to fit the crank in? What clearances are needed to do to the block?
              Here in ump pee land we have to run GM blocks. Any help would be greatly appreciated.
              Thanks
              Mike Bulpitt
              • stockcar5
                • 1289
                i thought the parts peddler retired? whats he doing on here talking non sense again???
                • perfconn
                  • 3636
                  Looks like your the dumb a$$ thats on here trying to sell parts.
                  • Verdoorn Racing
                    • Jan 2009
                    • 113
                    I'd say a 406 if you have a 400 block, otherwise a 396.
                    • racer69
                      • Apr 2009
                      • 249
                      Don't wanna join in the fire above! LOL
                      But I have learned a couple things from building motors for 2 very competitive asphalt 4412 classes.
                      Small motor isnt better than a big inch motor and the big inch isnt better than the small motor. I know y'all are thinking.."thats about stupid!" Hear me out. Each one has to be built and geared different than the other with the 2bbl. For the best small motor 4412 setup you need to build like a restrictor plate engine. Light weight parts, push compression limits, and very large heads and intake plenum. Based on math alone we know a smaller CID will turn more rpm with a cfm restriction compared to the big inch. Large runners and matching components will work together at the higher rpm. Just gear to match.
                      The big motor needs built with torque in mind. Port velocities become more important. The cubes alone will add torque and you have to capitalize on that. Smaller runners and longer strokes will help. On the dyno a 4412 421 would pull hard to about 6700. Then the drop was drastic. But the torque curve is what rocked it.
                      Thats my opinions from my experiences and I'm not claiming to be right. I'm just sharing what I have learned. Good luck, Jr
                      • let-r-eat
                        • 2319
                        I agree with Parot. Theoretically and by using physics the smaller cubic inch is capable of putting more power to the wheels, but driver preference matters.
                        BUCKLE UP NOW, YA HEAR?
                        • steveshawjr
                          • Jan 2008
                          • 430
                          i was always tought you don't feel hp. but torque you do.
                          what gets you off the corner and down the straight? torque
                          62 mini mod
                          • racer69
                            • Apr 2009
                            • 249
                            The old engine builders saying goes "You buy horsepower and drive torque"
                            I like my small cube motor in many ways but I like a good torque motor for different reasons. So I gotta agree with "driver preference".
