Power Differences
  • dirtdevil
    • 240
    Power Differences
    I know so much depends on many variables like cam, carb, etc. But in an outlaw mod that will only run a 1/2 track w/ no claim rules. What kind of differences would there be in following combos?
    3.75 stroke w/ 6.125 rod
    3.875 stroke w/ 6.00 rod
    4.00 stroke w/ 6.00 rod
    Also the heads would be a set of RHS aluminum 12062 64cc 235Int runner Intake HV1000
  • perfconn
    • 3589
    The last 3.75 stroke w/6.125 I did dynoed 715hp.The 4inch stroke would probably dyno 745hp on the same dyno.The 3.875 stroke would be somewhere inbetween.You need to realize every dyno will be different.
    • LateModel B23
      • Oct 2012
      • 283
      Perfconn - guess who this is !! It has been so long I had to re-register on here.
      I am going to be building a new motor for the mod for 2013. I have a question based on this original post. We will be running the Bowl with it, based on your visit that time - What do you think?
      • perfconn
        • 3589
        Bill,
        Haven't forgot you.I quite simply don't believe in puting a longer stroke than a 3.75 in a standard deck 9 inch block.I think on an 8 inch tire that would be more than enough motor even at the Bowl.
        How is the blueprint buisness doing?
        • LateModel B23
          • Oct 2012
          • 283
          Been busy.
          Been running that old 3.875 stroke w/ a cam I got from you years ago. Finished 5th in points. My son is driver now. Michael taking some time off.
          • perfconn
            • 3589
            I have retired now.I closed my shop because of the economy but I still help some of my old customers.In fact the 409ci that I referred to is being redone now.It only has Brodix 11X 23* heads on it and made 715hp.
