cam help
  • heneryss
    • Jan 2011
    • 6
    cam help
    our track is starting a new class called pure stock and the motor rule states that u have to be able to pull 18 inches of vacume at 800 rpm just looking to see if anyone had any ideas on a cam. there no lift rule, stock compression and dish or flat top pistons
  • usafracer
    • Jun 2010
    • 554
    Not sure on a cam but rhodes lifters will be your friend.
    • soonersublime
      • Jan 2008
      • 995
      If you are allowed an aftermarket cam then this opens up the rules a bit. Figure out which heads you are running and call a good cam grinder that can design a 18" vacuum cam for you and your ready to go.
      • heneryss
        • Jan 2011
        • 6
        yea were allow aftermarket cams just didnt know if anyone had heard so such a rule before and if it would be worth the money to get a custom cam or just stick with a stock one
        • soonersublime
          • Jan 2008
          • 995
          Custom cam all the way then.
          • soonersublime
            • Jan 2008
            • 995
            • hpontap
              • May 2008
              • 574
              Probably a hydraulic camshaft rule right? To pull vacuum the rest of the engine has to be in good shape also. Tight valve guides, good valve seal, ring seal, carb tune etc. There are off the shelf vacuum cams out there also if you dont want to spend a lot.Just do a search.
              • hogracer3d
                • 511
                If you are close while in tech, grab the distributor and give it a little advance. Should give you an inch or two of additional vacuum, for insurance
                • heneryss
                  • Jan 2011
                  • 6
                  after reading the article soonersublime posted should i call comp cams and see what they recommend or is there another cam company that may have a lil more expericence with vacuum rule cams
