What is the best head gasket for Aluminum heads with steel block?
  • racinjason29
    • Feb 2009
    • 470
    Whats the best head gasket to use? Brand and part # please I am running a steel block with aluminum heads, 3.47 crank, 6"rods, 2 valve relief flattops
  • LateModel B23
    • Oct 2012
    • 283
    What bore?
    • racinjason29
      • Feb 2009
      • 470
      4.030 is the bore size
      • LateModel B23
        • Oct 2012
        • 283
        Fel-Pro 1003 is what I would use.
        • usafracer
          • Jun 2010
          • 554
          I would use a mls gasket such as the 1142.
          • perfconn
            • 3573
            FP1043 will give you more compression with that bore
            • racer69
              • Apr 2009
              • 249
              The MLS gaskets work great AS LONG AS THE BLOCK IS SMOOTH! LOL That block I got burnt on last year wouldn't seal with them. Used the SuperSeal from Mr.Gasket. Stuck like glue! Too bad for the hidden crack beside the cam!
              Oh and I found your door!
              • ajanessaarley5642
                • Apr 2017
                • 1
                A Long-Awaited Update for This Compact Crossover 2018 Volvo XC60 2017 Honda Civic Type R Jaguar I-Pace Concept and more
                • Jeffery
                  • Jul 2011
                  • 65
                  MLS is what I bought, had a Fel Pro 1003 like above on it and it worked ok.
