Sealed Power Ring Help
  • Ferg58
    • 519
    Just opened up a box of sealed power rings for SBC. The top ring has no taper or marking. Anyone have a clue?
  • fast_crew
    • 844
    Rings should've came with a set of instructions, but generally rings with no dimple or taper, can be installed either way.
    Josh K.
    • CNC BLOCKS
      • 595
      Soundss like you have a set of cast rings.
      • Ferg58
        • 519
        CNC so are these junk? I called Fed Mogul and they said they were packaged wrong. Should be a dot and a taper.
        • 500BOMBER
          • 762
          The ones that are not marked are square cut and can go either direction.
          Old enuf to know better, still too young to givadamm.
