im have a mallory distributor looks like the msd distrubitor with the slip car when im on the track under power my distributor moves so my timming moves and the car dies , has anybody else ever had this problem what do I do ?
problem with distrubtor moving with the slip color ?
how are you setting the height on the colar? Ive never owned one but guys say you should drop it in w/o the gasket tighten the ring down and then pull it back out and put the gasket on and set timing. The dept should be correct then. Do you have a chrome dist hold down?
no i have aluminum one I will try that I orderd a new hold down from allstar that goes around the neck and tightens when a allen head holds it from moving so hopefully that works also.Originally posted by powerslide View Posthow are you setting the height on the colar? Ive never owned one but guys say you should drop it in w/o the gasket tighten the ring down and then pull it back out and put the gasket on and set timing. The dept should be correct then. Do you have a chrome dist hold down?
