I am getting back into racing after 5 years off. I know the oil has changed since I last raced. I always used the Kendall GT1 green oil. What oil should I run in my imca engine now?
solid cam oil question
Solid cam motor will need an oil high in Zink. I would run Brad Penn. Very high in Zink which will be perfect for your solid lifters.
Dave.2012 UMP Stock Car National Champions.
I use Kendall GT1 20-50. The race blend has the zinc in it and I can buy it locally for under $3 a quart. No oil related issues so far.
Yes,very high in zinc.I would put one,and 1/2 pints.As for the oil I would use schaffers 7000,It's great,and wouldn't need to use any EOS.Originally posted by avenger1 View PostI have about 7 pints of the old EOS assembly lube that G.M. sold. Would that work and how much per 7 quarts of oil?Last edited by lazermod3; 11-10-2013, 07:08 PM.you just got greased
http://www.goddardwarrior.net
